LabWindows/CVI
CVI_AppExitCVI throw exception in cviauto.dll
CVI_AppExitCVI throw exception in cviauto.dll. CVI5.0+VC6.0+Win98.
Code:
if (cviHandle)
CVI_AppExitCVI(cviHandle,NULL,1,NULL);
Exception is:
First-chance exception in PCT-32.exe (RPCRT4.DLL): 0x800706BA: (no name).
First-chance exception in PCT-32.exe (CVIAUTO.DLL): 0xE06D7363: Microsoft C++ Exception.
What's the problem?
(3,187 Views)
Hello
CVI 5.0 did not really provide any import libraries for use with Visual C++ 6.0, this was added in CVi 5.5 and above. Check out the "http://digital.ni.com/manuals.nsf/webAdvsearch/0F9E1E5F0D18DD7786256856006B179E?OpenDocument">CVI 5... pg 15 of 32, perhaps this might be causing a problem. How are you importing the function into Visual C++? If you are going to be doing alot of future development using Visual Studio and CVI, you might consider upgrading to CVI 6.0, there have been alot of improvements made to the interface of CVI's automation server (programatically making fp files being one of the many new improvements)
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,187 Views)
I create the Dll myself from cvisrvr.c & cvisrvr.h in CVI. Will this cause any problem?
Features of automation server in CVI5.0 are enough for my usage. If possible, I don't want to make too much change in my current project.
Thank you, Bilal.
(3,187 Views)
