LabWindows/CVI
CVI-Application = ActiveX-Server?
Is there any possibility to make a CVI-Application a ActiveX-Server, so
i can export functionality to other applications?
Torsten
Torsten Levin Tel.: ++49-(0)89-72495-451
Kayser-Threde GmbH Fax: ++49-(0)89-72495-291
Perchtinger Str. 3 mailto:TL@kayser-threde.de
D-81379 München http://www.kayser-threde.de
(3,407 Views)
If you create a DLL in CVI, you can imbed a type library in the DLL so it
can be called via ActiveX. You currently cannot build custom ActiveX Automation
servers in CVI, but that functionality will be coming in a future release.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
Torsten Levin wrote:
>Is there any possibility to make a CVI-Application a ActiveX-Server, so>i
can export functionality to other applications?>>Thanks >Torsten>>-- >Torsten
Levin Tel.: ++49-(0)89-72495-451>Kayser-Threde GmbH Fax:
++49-(0)89-72495-291>Perchtinger Str. 3 mailto:TL@kayser-threde.de>D-81379
(3,407 Views)
