LabWindows/CVI
CVI Client TCP Example doesn't work like Hyperterminal
If I attach to the server with the CVI client example I miss some responses or get partial responses to commands. If I connect with Hyperterminal using tcpip/(Winsock) it works fine.
What it returns:
VM0,1SE30000,2SE30000,1SV@26,1DI0,2VM0,2SV@26,2DI0,1MN0,1GO0,WA500,2MN0,2GO0,MC26,MC27,MC5,2WS1,2MF0,1WS1,1MF0,MC8,MC11,CF2,AL0,AR4
What it should return
MD3,1SQ2047,2SQ2047,1FR20,2FR20,1SA@6,2SA@6,CN1,CN2,WA1200,CF1,1VM0,1SE30000,2SE30000,1SV@26,1DI0,2VM0,2SV@26,2DI0,1MN0,1GO0,WA500,2MN0,2GO0,MC26,MC27,MC5,2WS1,2MF0,1WS1,1MF0,MC8,MC11,CF2,AL0,AR4
(3,284 Views)
Hello
Check to see if you have any null strings in the string that is being returned. BY definition, a C string uses '/0' as a end of string marker. The string seems cut in half so there might be something in the string that the CVI Client example might not be handling correctly and hyperterminal apparently is.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,284 Views)
