LabWindows/CVI
CVI Customize Library Missing by new windows user account
I have CVI 8.0.1.
At before I using windows account Administrator to write and build my source code. And project has Customized library added. At Library-->Customize --> Add.
Here is the library list: All these can be found in Administrator account to run the project.
C:\Program Files\National Instruments\CVI80\toolslib\toolbox\toolbox.fp    OK
C:\Program Files\National Instruments\CVI80\bin\easyio.lfp    OK
C:\Program Files\National Instruments\CVI80\toolslib\datasock\dataskt.fp    OK
C:\Program Files\National Instruments\CVI80\bin\niimaq.fp    Missing
C:\Program Files\National Instruments\CVI80\bin\nivision.lfp    OK
c:\Program Files\National Instruments\TestStand 3.0\API\CVI\tsapicvi.fp    Missing
c:\Program Files\National Instruments\TestStand 3.0\API\CVI\tsutil.fp    Missing
c:\Program Files\National Instruments\CVI80\bin\niimaq1394.fp    Missing
c:\Program Files\National Instruments\CVI80\bin\niimaq.fp    Missing
After, I join this computer to our domian, and user another domain account to login windows.
But as you see the library missing, when I use another domain user name.
The files are at the same location.
Is there any configuration or AppDataSettings bind with windows account?
I checked the envirouments for both account is same. Only temp folder is different.
I can't find any ApplicationData in Administrator profile folder.
I can't find any software project settings with windows account?
How can this happened? How can I fix that quickly? To one by one add them is annoying for each project.
(3,259 Views)
I faced the same situation as yours a few years ago but I can't remember the situation I found in the new user. It is possibile that some CVI settings are per-user, so when switching from a local to a domain account (which in effect is a new user) implies to reload them, nevertheless the list of libraries is global to the IDE so you will need to customize it only once.
Additionally, you may want to explore import/export settings facilty of CVI to move all your customization from the old to new user.
(3,246 Views)
But in CVI 8.0.1 I can't find this tool or that .exe file.
(3,240 Views)
You're right, I missed that detail Smiley Embarassed. The facility was introduced in CVI v9 or 2009.
(3,228 Views)
