LabWindows/CVI
CVI DLL PInvoke Error
I have a CVI DLL that  customer is trying to call from Visual Studio 2012.  The call works in VB6, but not Visual Studio.  Error is PInvokeStackImbalance.  Anyone else encounter this issue?  CVI prototype below...
int __stdcall TestDLL(int mode,int range,double q, double p,double *records,double *rec2,char *str);
(5,492 Views)
You don't say which flavor of Visual Studio 2012, they are using, VB.NET, C#, ?
here is tutorial for C#   http://msdn.microsoft.com/en-us/magazine/cc164123.aspx
(5,484 Views)
Customer tells me they are using Visual Studio 2012/VB, I presume VB.NET.  They claim there was a change from .NET Framework 4 that no longer automatically fixes problems with the stack.  Can the stack be packed in such a way to cause problems?
(5,469 Views)
Were they using a different version of Visual Studio before or were they using VB6?
In your first post they mentioned VB6 which leads me to think that they are not quite telling you the whole story.
It is quite easy to download VB.NET 2010 Express to verify.
(5,457 Views)
