LabWindows/CVI
CVI DLL run in VB, Panels don't work.
I have Written a dll in CVI, and run it in VB. I have a panel that is loaded using the CVI generated code (see below) but none of the controls on the panel will function (a control button will not even animate to show it being pressed), yet the actual panel callback still works (the close X at the top will close the panel).
CODE:-
int VigFDShowDebug (void)
panelDebug = LoadPanelEx (0, "VigFD.uir", PANELDEBUG, __CVIUserHInst);
if (panelDebug < 0) return -1;
debug = TRUE;
DisplayPanel(panelDebug);
RunUserInterface ();
return TRUE;
If you pause the program you can see it breaks on RunUserInterface().
Can anybode get my controls working???
Regards
Alex
(3,558 Views)
Hi Alex,
Did you make sure that you used the LoadPanelEx function? Please see the following link:
http://digital.ni.com/public.nsf/websearch/9A9A882B7A24BBBB86256CAA0075715D?OpenDocument
Phil R
http://www.ni.com/support
(3,558 Views)
Yes, the first line of the fuction is LoadPanelEx(). it is the same code that was generated from 'Code - Generate ALL'.
(3,558 Views)
Attached is the CVI project for the DLL, and the VB program to test it.
The Dll path is -
C:\My Documents\LabWindows\VigFDdll\vigFD.dll
The button to press in VB is "Show Debug" which calls the function 'int VigFDShowDebug (void);'
Hope this helps.
(3,558 Views)
Hi Alex,
The code seems to be missing "General.fp" (c:\drakard\FunctionPanels\General\General.fp) meaning that I cannot create the DLL. Can you supply this please?
Phil
(3,558 Views)
Sorry,
I have managed to get the program working by keeping all the uir generated code in a seperate .c file (from the VigFD.C file). So Im think I have done something wrong in the VigFD.c code.
If you get chance, it would be nice to know how it went wrong.
Regards
Alex.
(3,558 Views)
