LabWindows/CVI
CVI Dynamically determine 64 vs 32 bit machine
Is there some API, in CVI (LabWindows), that I can use to determine the architecture, 32 vs 64 bit, of the machine my app is running on?
The reason is that I have a call to open a file under 'Program Files' but if it is a 64 bit machine I need to make the call to 'Program Files (x86)'.
Or possible some macro that will point to the currenly installed folder of my application?
(5,417 Views)
Accepted by topic author atomic928
While I can't answer the exact question easily. I can provide some potentially helpful pointers:
  • See this question about locating "Special Folders" and how to use the windows API
  • Here is the API info.
  • Check the "Remarks" section here about 80% of the way down the page. You may be able to ask for one special folder and always get the right one, bypassing the need to determine the 32 vs 64 bit question.
All that said I don't have the answer to determining 32 vs 64 bits!
Hope this helps a bit.
Ian
(5,391 Views)
Your suggestions got me going to find the API, GetProjectDir(), which I adapted for my use.
Appreciate the help.
(5,365 Views)
I realize you probably don't need to differentiate between 32- and 64-bit any more, but if you ever need to again, this is how you can do it.
(5,268 Views)
Thansk LuisG,
Stuff like that always comes in handy.
I appreciate it.
(5,256 Views)
