LabWindows/CVI
CVI EXE producing R6030- CRT not initialize​d
I get this error on a win7 system with CVI 2012, every time that I try Linking to a specific dll that used to work in windows xp.
<MSG>
Microsoft Visual C++ Runtime Library
Runtime Error!
R6030- CRT not initialized
</MSG>
Can anyone help with this...?
Thanks in advance.
Message 1 of 11
(14,919 Views)
Hi skykeeper,
This is probably not an issue with CVI, since this is a C Run Time Engine error. Try running the program as an administrator; Windows 7 has increased security measures, and likely won't let you do a lot of the things you could in Windows XP.
Alexandra
Message 2 of 11
(14,902 Views)
I have tried running the exe as administrator and get the same error.
Also tried to run in XP compatibility mode no luck.
Message 3 of 11
(14,900 Views)
Hi Skykeeper,
This issue is not related to CVI, it can happen in any C development environment. I found a number of forums with possible solutions just by Googling "R6030- CRT not initialized".
Here are some tof the more comprehensive forums I found:
http://www.promixis.com/forums/showthread.php?21015-C-Runtime-error-R6030-CRT-not-initialized
http://forums.ni.com/t5/LabWindows-CVI/R6030-CRT-not-initialized/td-p/1857605
http://support.citrix.com/article/CTX133036
Look through those and others to see if those solutions fix the error that you're seeing.
Alexandra
Message 4 of 11
(14,890 Views)
OK, I narrow it down to the use of a dll that I built using LabView. Now I don't know why the error is comming up.
Any Ideas anybody?
Thanks.
Message 5 of 11
(14,868 Views)
Hi Skykeeper,
Does the LabVIEW code work on its own? You may have to go back to the LabVIEW Development System to troubleshoot the issue. If you do, consider posting a new discussion to the LabVIEW board.
Alexandra
Message 6 of 11
(14,851 Views)
The Labview Code Works fine. also the dll works fine when is used by it self, it generates the error when used in a project with more dll's, in particular a dll from PXIT (pxit306.dll) they both work if they are not in the project togheter.
I have use the pxit306.dll for a long time in a project with multiple dll's built by us, but it is the first time using it with this LabView created dll.
Very Confusing... ???
Message 7 of 11
(14,848 Views)
Hi skykeeper,
What do these two DLLs do? Please list all of the functions available.
Alexandra
Message 8 of 11
(14,839 Views)
Accepted by topic author skykeeper
Sorry for the delay. (busy with other projects)
I was forced to re-write the dll using CVI and the provided API, this works fine and have no conflicts with the other drivers and dll's.
Thanks for your Support.
Message 9 of 11
(14,555 Views)
Hi skykeeper,
Could you tell me how you solved the problem? I also encountered the same problem.
If possible, please try to be more detailed。
Thank you very much!
Message 10 of 11
(6,475 Views)
