LabWindows/CVI
CVI Error: Over Array Bounds
When the attached C-File is compiled and executed in Debug mode CVI fails with an Over Array Bounds error while dereferencing a valid char * pointer. The function 'LogEnetData ()' is passed a pointer to over a thousand bytes of valid data and yet CVI declares an error when the loop index is 2.  I believe that this violates standard C behaviour.
When I single-stepped through the code and monitored the value of pData after it had been incremented, I got the following results:
          i                              pData
          0                        0x0012FA6D                        This is OK
          1                       "Over Array Bounds"
(3,532 Views)
Towards the end of your file, you have the line:
    LogEnetData (fp, Message.MsgSize, (unsigned char *)&Message.CsciSource);
You should be using the .Data field of your structure, not the .CsciSource one. Like this:
    LogEnetData (fp, Message.MsgSize, Message.Data);
JR
(3,528 Views)
I am using the CsciSource field because that's where the logging needs to start
Hurst C.
(3,512 Views)
