LabWindows/CVI
CVI/Linux hangs when using graphs
...wanted to send this by other means...
(3,512 Views)
Hi gdargaud,
Can you be a little more specific about the source of the problem and what occurs before the hang? One common reason for this behavior is running time intensive pieces of code inside Callbacks which prevents the processing of GUI events and gives the appearance of hanging the interface.
Milan
(3,495 Views)
Hello Milan,
you must have seen the original post before I edited it out (not possible to delete messages?)
The problem is currently being looked at closely in another thread.
Thank you.
(3,490 Views)
