LabWindows/CVI
CVI Newbee: Can I use CVI controls in VC++???
Hello folks!
I'm totally new to CVI, but am used to VC++ 5.0 / 6.0
For a new project that includes lots of hardware stuff I would like to
combine the power of VC++ MFC and CVI.
- MFC gives me the best flexibility in designing my applications user
interface and I'm used to object orientated software design.
- CVI would save me a lot of time by providing powerful hardware interfaces
and easy to use controls.
I've created a test project with VC++ 6.0. It was simple to include a RS232
interface (just a test). I only needed to include "RS232.h","CVirtE.h",
"CVIDef.h", and cvirt.lib" to my project.
Now I'm trying to include CVI controls like an analog meter to a VC++ test
dialog...
Does anyone of you can give m
e a short insight on how to do that or can
provide links to articles about this topic?
Any help is appreciated!
Ciao
Henryk
(3,588 Views)
It would be very difficult to include CVI controls in VC++ dialogs. VC++
dialogs follow a completely different model where every control is its own
window, which is unlike CVI. You can mix CVI dialogs and MFC dialogs/views
in the same project, but not CVI controls on MFC dialogs/views. There is
a very good solution for you though. CVI is now sold in a suite of products
called Measurement Studio which has tools for VC++ and VB in it. It includes
a set of UI controls for VC++ MFC programs that are similar to the set in
CVI. If you are using the latest version of CVI (5.5) it is on the same
CD and called ComponentWorks++. If you are using an older version of CVI,
you can upgrade and get the latest CVI with all of Measurement Studio for
only $295. For more info
on Measurement Studio, go to: http://www.ni.com/mstudio/.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
"Henryk Mueller" wrote:
>Hello folks!>>I'm totally new to CVI, but am used to VC++ 5.0 / 6.0>>For
a new project that includes lots of hardware stuff I would like to>combine
the power of VC++ MFC and CVI.>>- MFC gives me the best flexibility in designing
my applications user>interface and I'm used to object orientated software
design.>>- CVI would save me a lot of time by providing powerful hardware
interfaces>and easy to use controls.>>I've created a test project with VC++
6.0. It was simple to include a RS232>interface (just a test). I only needed
to include "RS232.h","CVirtE.h",>"CVIDef.h", and cvirt.lib" to my project.>>Now
I'm trying to include CVI controls like an analog meter to a VC++ test>dialog...>>Does
anyone of you can give me a short insight on how to do that or can>provide
links to articles about this topic?>>Any help is appr
eciated!>>Ciao>>Henryk>>>>
(3,588 Views)
Thank you for your answer! That's what I was "afraid" of. At a first glance
I could see that the controls work totally different to VC++ dialog items
(Callbacks and stuff).
I found a possibility to work around this problem:
One need to create a panel without a frame and title that is exactly as big
as the control and include this panel into a VC++ project. Then you can lay
the panel over a dialog so that it looks like the control is part of the
dialog. But it's takes a lot of effort to let the control behave like a
"real" dialog item. For example you have to move the panel every time the
user moves the dialog.
As far as I know we have only CVI 5.0.1 in house. I guess the discussed
problem is a good reason to upgrade to CVI 5.5... ;o)
Ciao
Henryk
(3,588 Views)
