LabWindows/CVI
CVI PID Library not installing
I'm trying to install the NI PID Library in CVI 2012, I ran the install program and it doesn't show up under the Library Tab?
(3,508 Views)
Accepted by topic author cjp1
You must run Library >> Customize menu function and then browse and add the proper library (which on my Win7 machine is located in C:\Program Files (x86)\National Instruments\Shared\CVI\bin\PID.lfp), then restart CVI.
(3,495 Views)
Thanks for your help. I did find the PID.lfp library and installed it.
When I first went looking for it I looked for pid.lib
(3,489 Views)
