LabWindows/CVI
CVI PlotXY refresh
I am reading a data file from another PC that is updated every four seconds.  I want to do a xy plot with four traces.  How do I refresh the data for plots 1 through 4?  Everything I try always generates new plots.
(3,136 Views)
Paul,
You cannot change the data used by a plot. The way you refresh a plot is to delete it and then re-plot using the new data. From a performance standpoint, it's no less efficient to do this then it would be to change the data of an existing plot.
Just be sure to pass VAL_DELAYED_DRAW as the last parameter of DeleteGraphPlot, in order to avoid double-drawing, which would cause flashing.
Luis
(3,118 Views)
