LabWindows/CVI
CVI Project convertion error
When I do the convertion of CVI2010 Project in VS2008 IDE, a dialog which says "Cannot find the VXIpnp Directory." pops,how to deal with this problems? Thanks!
(4,798 Views)
Hello Simon!
Did you install the IVI Compliance Package?
(4,741 Views)
Hello Johannes_T! Thank you for reminding me,when I was installing the CVI2010,drivers were not installed.But where can I download  the  IVI Compliance Package which is matching with the installed CVI version(CVI 2010)?
(4,663 Views)
You can install the ICP from the following location: https://www.ni.com/en/support/downloads/drivers/download.ivi-compliance-package.html#307083
Note, that if you also want to use the IVI Configuration utility, MAX also needs to be installed, which you can download from: https://www.ni.com/en/support/downloads/drivers/download.ni-device-drivers.html#327629
(4,654 Views)
