LabWindows/CVI
CVI Run-Time
I have to use an application in LabView through CVI.
Now when I launch the application (LabView), I am able to send only one command, while I need to send a several commands. How can I keep application in run time (LabView) for all time I need to send commands.
With Best Regards
(3,159 Views)
Does your application normally require you to use the run continuously functionality in LabVIEW? If so, you need to use a while loop with a stop button to programmatically run the application continuously rather than relying on the run continuously button.
Ryan K.
(3,144 Views)
