LabWindows/CVI
CVI Run-Time
I have to use an application in LabView through CVI.
Now when I launch the application (LabView), I am able to send only one command, while I need to send a several commands. How can I keep application in run time (LabView) for all time I need to send commands.
With Best Regards
(3,866 Views)
please, could you explain me your issue with more specifications?
For example: your CVI and Labview versions, how you call the labview VI from CVI, what communication are you using to pass the commands...
regards
AlbertoA
(3,866 Views)
Thank you very much for your answer.
I am using CVI vers. 6 and LabView 6.1
I would like to use ActiveX.
Best Regards.
Saretta.
(3,866 Views)
try to use the following examples:
1.LabWindows/CVI Controlling LabVIEW
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3D9E156A4E034080020E74861&p_node=DZ52000_US&p_source=External
2.Using LabWindows/CVI as an ActiveX Client to Run LabVIEW VIs.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DB5F56A4E034080020E74861&p_node=DZ52156
3.ActiveX
http://zone.ni.com/devzone/devzone.nsf/webcategories/A247F2BD6FD11D8D862567A90058B72D?opendocument&node=DZ52156_US
4.General
http://zone.ni.com/devzone/devzone.nsf/webcategories/46E7994B7483D781862567C300662667?opendocument&node=DZ52051_US
Regards
AlbertoA
(3,866 Views)
Thank you very much.I am so happy for your help.
I will try.
Best Regards.
Saretta (little Sara)
(3,866 Views)
