LabWindows/CVI
CVI - Synchronizing two AI signals using PCI-6251
Hi all,
The application which i am trying to develop with my NI PCI-6251 M-series DAQ card is to synchronize the two sine wave signals acquiring from  AI0 and AI1 respectively. The source of the first sine wave signal is Analog ouput 0 (AO 0) of the same PCI-6251 card and the second sinewave signal that i am acquiring is externally coming from function generator.Both the signals have same frequency.
The problem which i am facing is that the two signals are not synchronizing. One signal that i am generating from   AO 0 is still ( Acquiring from AI0 ) and other from function  generator is continuously rotating (Acquiring from AI1).
I am also using the ANALOG TRIGGER but synchronization is completely out.
DAQmxCfgAnlgEdgeStartTrig (*inputTaskHandle, "Dev1/ai0" , DAQmx_Val_RisingSlope, 0.0);
I have also Tried Digital Trigger like aiStartTrigger, aoStartTrigger, aiSampleClock etc but the response remains the same.
Any help will be greatly appreciated.
(2,827 Views)
Could you describe what you mean by "The two signals are not synchronizing"?  Screenshots would be helpful.
Do you mean the the triggering is inconsistent?  Are you doing a finite or continuous acquisition?  It sounds like you are trying to set it up so that the acquisition will begin when the signal on channel
AI0 has a positive slope with a level of 0.  Are you seeing something other than this?
Jon
(2,814 Views)
