LabWindows/CVI
CVI applications can run in Linux ?
Hello
Ask: 1 in Windows to write CVI applications can run in Linux? And Linux must have the LabWindows/CVI 2010 Linux Run-Time module??
 The 2.Linux can support the CVI development environment?
(3,259 Views)
There is some sort of support for running applications on Linunx, even though you cannot directly run the IDE on it.
Shortly, you will need to develop on Windows and then compile and run on Linux system. I don't know how easy is all this process as I only develop for Windows systems.
A lot of informations can be found in this White Paper [broken link removed].
The Linux Run-Time Engine is a module to be purchased separately.
(3,254 Views)
First of all to thank you for your reply
I also want to know Linux Run-Time module have to buy? No free download?
Thank you
(3,245 Views)
No, it's not free download.
When we were considering moving some applications to Linux we found that neither an evaluation module was available like the one for Windows, but that was a few years ago and this can be changed now. We have not proceeded on that project so I have no actual on-field informations on this matter.
(3,241 Views)
