LabWindows/CVI
CVI: compile et create a executable with Visual C++ project
I compile a C project with VISUAL C++ 2005 (I use a example project from Gsoap).
The project can be compile et create an executable with VISUAL C++.
I can not compile the project with CVI.
I have a problem of link (__snprintf, _write, _read ....)
Do you have a solution please?
(4,004 Views)
in C, there is a convention which states that vendor specific functions (those that are not part of the standard) have their name starting with an underscore ('_'). check your code, you might be using non-standard functions. i can already tell you that snprintf is one of those functions. you can easily find replacement functions or alternative ways to perform the same thing.
(3,969 Views)
Thanks for your message.
I have a problem because when I use the fonctions without underscore.
I add the file stdio.h from Microsoft Platform SDK to the project. The fonctions snprintf and _snprintf are defined in this file.
I have always compile errors like:
"Missing prototype"
I used CVI 7.0.
I can use the CVI 9.0 with evaluation.
(3,967 Views)
Hi Daniau !
Dummy is right !
This error is not exclusive of LabWindows/CVI. It is a standard error that any C compiler will generate whenever you try to call a function that has not been declared previously.
It is very commonly generated when a function name is misspelled (i.e. typing print instead of printf).
Another cause would be when you don't use the void keyword for a function which does not receive any arguments.
Try declaring the function as: void my_func(void); instead of :  void my_func();.
(3,958 Views)
