LabWindows/CVI
CVI function not a number%2C path or refnum
What CVI function should I use for not a number, path or refnum? Also, function to check for an empty path or empty file.  Examples including would be greatly appreciated.
(4,444 Views)
Not a number, not a path, not a refnum are LabVIEW concepts that do not apply to CVI.
Paths in CVI a simple strings, so "not a path" can be an empty string.
The Programmer's Toolbox give a NotANumber () function that you may want to use to initialize a (double) value as well as a IsNotANumber () function for tests.
There isn't a C equivalent to RefNums: C (and CVI, of course) can use handles which are usually integers or unsigned integers, but other datatypes can be found in several libraries: each of them must be initialized in its proper way.
(4,434 Views)
