LabWindows/CVI
CVI incomplete/missing popup panels
Using CVI 6.0 under W2000 with MS VC++ 6, i sometimes can bring execution of my application to a halt by invoking a CVI message or prompt popup from a menu command callback procedure. The popup does not appear or appears without buttons and execution is stuck. I have to stop debugging and restart the application. I am using a Matrox G450 with two monitors, but they are configured as one large monitor, GetSystemAttribute(ATTR_NUM_MONITORS,..) returns 1. Sometimes the hangup is reproducible several times, then it disappears, possibly after closing other CVI applications before debugging again. Has anybody seen such behaviour?
I checked this is not a multithreading problem (my modal popups are created from the same thread as main panel). I am
using the system attribute to have CVI popups with 3D buttons.
(3,580 Views)
I have never experienced this behavior myself. I noticed you are using 3D buttons. Does it behave differently with the Classic Style buttons? Also, does this happen when you evoke the Panel by some way other than a menu command callback? For instance, if you just call "ConfirmPopUp", does it freeze up also? This would be interesting to know. Let us know what you find out.
J.R. Allen
(3,580 Views)
I am having similar issues, whereby I sometimes get incomplete popup panels using CVI 7.1.1.
I tried updating the style of the popup panel to VAL_LAB_STYLE for the rendered buttons, but
the message and confirm popup are still in the classic style.
I am setting the POPUP_STYLE with
SetSystmePopupsAttribute(ATTR_POPUP_STYLE,VAL_LAB_STYLE) and verifiying
with GetSystemPopupsAttribute, but popup panels are not changed.
Any feedback would be helpful
(3,238 Views)
