LabWindows/CVI
CVI on Linux64 ?
Hello all,
so far I've only ever used CVI for Linux on 32 bits systems (for both the
compiler and the runtime).
Do they both work on 64 bit distros ?
Guillaume Dargaud
http://www.gdargaud.net/
(3,763 Views)
Because we don't officially claim support, we haven't done extensive testing, but I have tried it and things seem to work.  You can find more information on this thread.  Note you're still just creating 32-bit applications that are running on the 64-bit OS.
NickB
(3,760 Views)
Thanks, I'll try it out then. I didn;t want to waste time installing a 64-
bit distro if there was no chance of it working.
> Note you're still Note you're still just creating 32-bit applications that
> are running on the 64-bit OS.just creating 32-bit applications that are
Hmmm, still it's only a bunch of options passed onto gcc, I guess it'd only
require playing with them to get a full 64-bit executable...
Guillaume Dargaud
(3,747 Views)
Well - the problem is that the cvi libraries (libcvi.so etc.) are only 32-bit.  This limits you to creating 32 bit applications if you are going to link against the CVI libraries.
- Nick
(3,745 Views)
