LabWindows/CVI
CVI short data type
I found this problem using a "short type" inside a structure: in the
LabWindows/CVI Programmer Reference Manual page 1-5 the type "short" is
declared to have a size of 16 (2 bytes) . I used the function sizeof()
to get the size of a variable short and it returned 2; but when I tried
to use the same function for a member of a structure of type short, it
returned 4! How can this happen? A short is a short...am I wrong?
Example
short var1;
typedef struct
short var1;
} DataType1; DataType1 data1;
sizeof(var1) : returned 2
sizeof(data1.var1) : returned 4 ......mistery of my compiler?
Thanks a lot
Samuele Gazzani
(4,110 Views)
You might see if the struct is being padded (to get it on a 32 bit
boundary).
This is a function of the processor and the compiler options you are using.
Kevin Kent
samuele gazzani wrote:
> Hi,
> Example
> short var1;
> typedef struct
> short var1;
> Thanks a lot
> Samuele Gazzani
(4,110 Views)
CVI (and every other compiler) packs structures to boundaries depending
on the processor type and operating system. On windows the default
packing is ( i guess) on 4 byte boundaries. That's why your short
occupies 4 bytes rather than 2. The same will happen if you define a
byte value (char) in a structure, then there are 3 bytes overhead.
CVI offers the possibility to control the packing of data structures by
pre-compiler directives:
#pragma pack(push) // save the default packing (normally 4)
#pragma pack(1) // set new packing to 1 byte
typedef struct // define your "packed" struct
short var1;
char var2;
#pragma pack(pop) // restore the previous packing
Torsten
samuele gazzani schri
eb:
> Hi,
> Example
> short var1;
> typedef struct
> short var1;
> Thanks a lot
> Samuele Gazzani
Torsten Levin Tel.: ++49-(0)89-72495-451
Kayser-Threde GmbH Fax: ++49-(0)89-72495-291
Perchtinger Str. 3 mailto:TL@kayser-threde.de
D-81379 München http://www.kayser-threde.de
(4,110 Views)
Ok,
Thank you so much!i'll follow your suggestion
Regards
Samuele Gazzani
> short var1;
> char
var2;
> Regards,
> Torsten
> samuele gazzani schrieb:
> > Hi,
> > Example
> > short var1;
> > typedef struct
> > short var1;
> > Thanks a lot
> > Samuele Gazzani
> Kayser-Threde GmbH
(4,110 Views)
