LabWindows/CVI
CVI slow to change active project since AgentSVN configured
Since i use agent svn i have found that it take way to much time to change a project, and i am wondering what cause it and if i can do something about it.
I've check the computer perf and see nothing that can stuck CVI.
Is there someone here that encounter this issue?
i've made a video about it
(2,456 Views)
Hey jungledede,
I'm afraid I've not used agent SVN before, but I do have some suggestions which might help narrow down the cause.
1. Try disabling agent SVN and see whether this speeds up CVI again.
2. Try using a different development environment such as Eclipse, and see whether similar slowdowns occur.
If both slow down, then it seems like it could be an agent SVN issue.
I have taken a look through our bug reports, known issues, and previously reported issues, and this has not been mentioned as an issue before with CVI.
If you contact your local support department, they will be able to help troubleshoot this in more detail if it is a CVI issue.
Cheers,
Mitch
(2,401 Views)
