LabWindows/CVI
CVI to PDF
Thanks Ian,
In fact, I succeed in making changes in the Adobe PDF printer by setting different values in the registry but I had to previously stop the Spooler service and restart it after the changes, that means that the computer user should have administration rights wich is not always the case.
Thanks again for your answer.
SG
Message 11 of 12
(1,823 Views)
I use NI_Report the first time and I´m realy faszinated..easy and good looking. One thing what I do not get is: I want to use ACROBAT PDF as a default printer.
The result is that I do not get the Acrobat File-Window. In the printer queue can I see a job without a file name and then it get stuck.
Can you give me a hint how I get the Acrobt window to be able to name the file.
The best way would be: naming the file inside of CVI and save a PDF without any prompt.
Thank for Help
Message 12 of 12
(1,470 Views)
