LabWindows/CVI
CVI using SCC agent SVN : files are not in read only at first use
Hello all,
For versioning, I'm trying to use agent SVN with CVI.
This seems to work fine for creating a project.
The point is that, at first opening of any file, without checking-out any file, I can modify them (ie : files are not in read-only mode).
And after doing a first check-out / check-in, the file will now be in read only mode.
Problem is, for sure, coming from agent SVN software which has downloaded file from repository but not put all in "read-only" mode.
Does anybody have the same issue and fixed it?
One first solution, which is not sustainable, is, after creating the repository link and downloaded source files, to go in explorer and activate manually all files read-only mode. But when project have many folders, it becomes difficult to put only files as read-only...
(2,039 Views)
Hello G_L_I,
I think the problem comes from the configuration of AgentSVN, have you tried to contact their support?
Maybe they can give you steps to make it work with LabWindows/CVI.
Have a nice day!
Clement
(1,992 Views)
