Hy there,
I got similar problems:
Working on a WinNT 4, Servicepack 6 Workstation, CVI 5.5.
I tried to install the SQL Kit 2.0, but got the error message S32EVNT.dll and SYMEVNT.386 do not match.
When I try to use any database functions, I get the message: The application or dll c:\winnt\sys32\cdbas13.dll is not a valid WinNT image. Please check this against your installation disk.
The file is dated 4/14/98, which doesn't correspond to any other file installed with the tool kit...
I tried to reinstall it, but with the same result.
I am able to connect to database (Sample Project connect.prj) but that's about it. I can't create new entries nor query a database.
Did you find an error or a aork around?
Cheers
Harald
HIlg@gmx.net
