LabWindows/CVI
CVI2013 : link error when using optimization
I'm using CVI2013. When I build my application without optimization, it works fine.
When I used an optimization, a link error appears :
  error: Undefined symbol '_sqrtf' referenced in "c:\Travail\CVI\appli\VagueDirMk4\cvibuild.VagueDirMk4_1\Release\decli_nord_magn.obj".
Any idea ?
Alain.
(4,852 Views)
Hello Alain,
Do you think you could provide us with a sample? What level of optimization were you using?
Nelu F. || National Instruments
(4,850 Views)
Thank you for your answer.
I try with all the levels of optimization with the same results.
Here is a zip with the project (it's an extract with the code that is generating the error).
Alain.
(4,846 Views)
Hi Alain,
Thank you for the code snippet. I have opened a report (id #428743). The issue should be fixed in a future release.
(4,842 Views)
