LabWindows/CVI
CVI2013 unable to load LabView RunTime-Engine?
Now I have tested your code again. I changed the structure of the code a little bit.
I can run the new code with no error.
Please see the attachment. My Code and Exe is called "myNI_test.exe" and "myNI_test.c"
Best Regards
Bernhard
Message 11 of 22
(2,663 Views)
I cannot run the exe-file neither your project from CVI. Always the same system error 998.
I do not understand why the your changes in the code should make any difference.
Gunther
Message 12 of 22
(2,660 Views)
ok.... mpf
I can also run your application if I change your code and structure of the worksheet like in the
following picture.
Perhaps this helps
Message 13 of 22
(2,656 Views)
Ok.....
one what you can try is:
                  ->don't load an external modul in the Build>>Target Settings.
if you have checkmark there the external modul, please try to uncheck this.
Message 14 of 22
(2,655 Views)
I have reinstalled the complete CVI2013 FDS hoping that solves the problem, but still the same.
The option "Enable LoadExternalModule" is always disabled.
Gunther
Message 15 of 22
(2,638 Views)
Ok, this sounds not good.
Could you send me your current C Project and Workspace again, please. And screen copies
from all of your CVI environment settings.
I will try to reconstruct your settings and project. Maybe I find the issue.
Best regards
Message 16 of 22
(2,630 Views)
When you click on my Profile, you will find my eMail. In the case that the DLL and other things are confidential.
Message 17 of 22
(2,628 Views)
I cannot find your email address in your profile.
Gunther
Message 18 of 22
(2,620 Views)
Hi Gunther.
I write you back in the forum because it is maybe interesting for other CVI users.
I tried your settings and example. But I didn't obtained the error. I see in your source file
you have your project on an other drive than c: . Is 😧 your root drive? If not,
can you copy your CR project folder to your root drive( c:\) and try it again, please.
best regards
Bernhard
Message 19 of 22
(2,600 Views)
I tried it out, but this doesn't change anything (of course).
My original project is on c:\ (root drive). Only for separating I have made this test project on drive d:\.
I cannot see why it shouldn't work on another drive than the root drive.
Best regards
Gunther
Message 20 of 22
(2,595 Views)
