CVI6 and JPG images
Hi all, in an application of mine I am trying to load a JPG image into a picture control using DisplayImageFile command. The operation succeeds in my development machine while it fails on the customer machine with only the Run-Time installed: it returns error code -17: "PCX image is corrupted or incompatible with current display type."
The application is developed in CVI version 6.0.0.
Now, on my machine I have installed version 7.1.1 too, so the run-time engine is that one (CVI6 application declare it is running with 7.11 engine), while on my customer machine it declares (correctly) that it is using run-time version 6.00 (using GetCVIVersion () / 100.0)
Question: is this subject run-time dependent? That is: may I expect that installing the run-time version 7.1.1 even CVI 6 applications can handle JPG images? If not, why my computer displays correctly the image? I don't think the error message about the display type is correct since I can preview this jpg with Windows Picture Viewer.
Both computers are running WinXP with SP2, screen mode is 1024x768 with highest color quality (32bit)
(2,849 Views)
CVI 6.0 did not support JPEG image format. I think JPEG support was added in 7.1 or so. You could try updating the runtime engine on your user's machine to 7.1.1 and that should probably make it work.
(2,831 Views)
