LabWindows/CVI
CVI7 and NI Switch Executive ?
How to get CVI support for Switch Executive 1.0.1 Development System on a System with CVI7 ? The option for installing CVI support is disabled, when I install Switch Executive. With CVI6 there wasn't such a problem.
(3,417 Views)
Markus,
You should get the Switch Executive 1.0.2 upgrade from NI (it's a free upgrade). With that version you should be able to install it with CVI 7.0.
Luis Gomes
NI
(3,417 Views)
How to get that upgrade ?
I couldn't find any pointer to Switch Executive in the "Drivers and Updates" section of www.ni.com.
The support/switchexecutive subdirectory of ftp.ni.com only contains a unversioned patch subdirectory from 2002, which seems to be too old.
And the Update Utility in MAX also doesn't seem to know Switch Executive.
(3,417 Views)
Hi Markus,
You should request a FREE NI Switch Executive 1.0.2 Development System Upgrade CD from your NI Inside Technical Sales Consultant. The P/N to request is 850546B-03. You should recieve the update within 48 - 72 hrs from requesting.
Richard McDonell
NI Switch Executive
Product Manager
(3,417 Views)
Hi Markus,
It is my understanding that NI Switch Executive 1.0.1 works with CVI 7.0. I have asked the development team for confirmation. I will keep you posted.
NI Switch Executive 1.0.2 is now available as of last week. I would encourage you to use this version since it definitely supports CVI 7.0 and contains a number of performance enhancements and fixes for known issues.
Richard McDonell
NI Switch Executive
Product Manager
(3,417 Views)
