LabWindows/CVI
CVI8-"LIST"-orders its items in what an order ?
hallo,
using the "List" comming with CVI8 I have some trouble. the list makes its own "sorting", but I wanted to have the order just like i put the items into the list. any idea ?
best regards
Simon
(3,545 Views)
Hello Simon,
are you talking about the List Box control, or about the Lists from the Programmer's Toolbox library?
(3,523 Views)
One of the advantages is, that you can remove or insert single items in the list, without having to reorganize the whole list. Because of that, there is no default order of items in the list, its a simple collection of items with the same type. If you want the items ordered, you have to sort the list with the function ListQuickSort or ListInsertionSort. Alternativley you can add elements sorted with the function ListInsertInOrder.
(3,522 Views)
ok, but -thinking in JAVA- if the collection is a "List" (and not a "set" or "map") I thought the order stays just like the order I put the items into the list ?
best regards
Simon
(3,517 Views)
Hello Simon,
The order of the List items should indeed remain the same. I'm also using Lists and I never got any problems with the order. Are you using the function ListInsertItem to insert the items? And are you using FRONT_OF_LIST or END_OF_LIST as the last parameter for this function?
(3,512 Views)
ok, I am a fool: the index of the lists begins with "1". (who ever makes such things!)
best regards
simon
(3,482 Views)
