12-12-2019 04:18 PM
I am developing an application that is launched from a Windows service. This application links to several DLLs which, indirectly link to cvirte.dll. This procedure succeeds when I am working from my development setup.
I created a Windows installer for my application, however, when the Windows service launches the application from its directory within %ProgramFiles(x86)% it fails.
From a dump of the failing process I find the following exception:
Unhandled exception at 0x774F1E0B (ntdll.dll) in app.exe.8480.dmp: 0xC0000005: Access violation writing location 0x00000014. occurred
and the associated call stack:
ntdll.dll!RtlpWaitOnCriticalSection()
ntdll.dll!RtlpEnterCriticalSectionContended()
ntdll.dll!_RtlEnterCriticalSection@4()
cvirte.dll!687df3cc()
[Frames below may be incorrect and/or missing, no symbols loaded for cvirte.dll]
cvirte.dll!685c967a()
cvirte.dll!685b4b4a()
cvirte.dll!688007c3()
cvirte.dll!688351f1()
cvirte.dll!688352b4()
[External Code]
The interesting thing is that I only get this error when the application is installed and is then launched from the Windows service. I can launch it manually, whether or not installed, or it will launch from the service when the service is started from script.
My assumption is that this failing code is a part of the DLL initialization code since my application's WinMain function is never hit when I get this failure. I expect that cvirte.dll needs access to a resource but due to some security constraints it cannot reach it and then fails in ntdll.dll when it tries to proceed. Without knowing what cvirte.dll might be doing I have not been able to confirm my hypothesis.
Version information:
cvirte.dll: 17.0.0.295 (32-bit) from NI Automated Test Software Suite (SPR18)
Windows 10: 1809 (OS build 17763.914)
12-18-2019 01:29 AM
Is your service a 64-bit process?
My guess is that something in the special session in which services run is not exactly as setup in terms of file redirections as under the standard interactive session which takes internally extra precautions to allow all kind of cross environment invocation.
