LabWindows/CVI
CVIRTE.DLL problem with Windows XP
I've installed the developed appl. but there's an error "cannot find cvirte.dll" . I am using Windows XP Professional, and have also installed the CVI Runtime release 6 available in this site. The file (DLL) is in my hard-disk, but something happens that the runtime cannot recognize that library, or it does not run on XP. Can I have any other solution for this ?
(4,397 Views)
The DLLs (cvirt.dll, cvirte.dll) need to be in your windows system32 directory. Verify that they are present in this directory.
Best Regards,
Chris Matthews
(4,396 Views)
Hi Chris, thanks
The DLL files are in that folder.
But when I run the application it shows the message that "CVI runtime engine message : Windows was unable to load DLL cvirte.dll"
Could you please help me again with that ?
Thanks in advance...
(4,396 Views)
I'm really not sure what is causing this. I am using XP here and have no issues and I don't think we've seen any issues like this before. Is your project just a normal CVI project or are you in another compiler? Also, check the version of the DLL file and make sure it is version 6.0.X.
Chris
(4,396 Views)
