Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
CVITdms library - memory consumption problem
Oliveira
Member
02-11-2008
12:49 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi all!
I am using a Diadem library to create .tdms files
Through the DLL, I create and open a file and so, I start to append data values.
When I look at the task manager, I can note that the memory consumption of my application does not stop to increase until I stop my program.
I also tried to start the program without start the logging methods, that use the tdms libraries, and so, this behavior does not occur.
I flush the data every 30 seconds or every 500 registers.
How can I solve this problem of memory consumption?
Regards
Gustavo
0
Kudos
Message
1
of 3
(3,607 Views)
Reply
Re: CVITdms library - memory consumption problem
Herbert Engels
NI Employee (retired)
02-11-2008
07:28 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Does memory go back to normal after you stop logging or does it stay where it had been during logging? Will it further accumulate if you start and stop logging multiple times?
Herbert
0
Kudos
Message
2
of 3
(3,599 Views)
Reply
Oliveira
Member
Author
02-12-2008
03:33 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The memory consumption only occurs when I load cvitdms library. I load it dynamically.
Any idea? Is it a bug?
Regards
0
Kudos
Message
3
of 3
(3,591 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
