LabWindows/CVI
CWGraph X time axis problem
I'm using Labwindows 6.0 FULL and Win2K, here is what I would like to do. I have data and each data has its own time and date when it was sampled. Examples let's say that I have those values:
10.32 @ 01/12/02 11:20:34
14.15 @ 01/13/02 23:10:34
19.20 @ 02/14/02 09:11:10
22.03 @ 05/01/02 00:00:01
I have set my X axes in time, but I can't plot the value dunno why...Does anyone know what I have to do or any code example ?
Thank you,
(3,192 Views)
If you want to plot time values, and have a set time range which you want to plot between, the easiest way to do so are values pairs for your axes. This could be done with:
CWGraph1.Axes.Item(1).ValuePairs.Add.Name = "12:00:00:000"
CWGraph1.Axes.Item(1).ValuePairs.Add.Value = 1
and so on.
(3,192 Views)
