LabWindows/CVI
CWGraph Yscale does not match values
Did you guys notice that if you draw a line let's say all values set to 12.4 (float) in a CWGraph. The Y scale 12.4 have an offset with the line, I mean its not matching. Their is a good error introduced in the reading, why ? is this because of the autoscale ?
Thank you,
(3,042 Views)
I have not been able to reproduce the behaviour that you are seeing. I took the graphs project from \samples\usrint\ changed the left axis on the plot to autoscale and 10 division, and changed the data point generation code to read:
/** Generate some random data first **/
for (i=0; i<100; i++)
datapoints[i] = 12.4;
Run it, plot it, and it's right on.
Do you have any more specifics or reproducing this? Did following these steps clarify anything?
Amaury R.
-NI Applications Engineering
(3,042 Views)
