LabWindows/CVI
Calculating AutoPower and AmpPhase Spectrum in one step
in my application I need the information of the AmpPhaseSpectrum function and the HarmonicAnalyzer for which the AutoPowerSpectrum is needed.
For performance issues, Is there a possibility to calculate one of those spectrums out of the other without calling both those functions ?
Thanks a lot
Bernd
(3,299 Views)
Hello Bernd,
thank you for contacting National Instruments. I would like to help you, but therefor I would like to have more detailed informations about your application. What kind of software did you use in which version? Did you use a special toolkit to realize your programming steps? Did I understand you correctly? You want to force up the performance of your application by seperating the mentioned functions, or?
Best wishes,
Jan Kniewasser, NI Germany
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(3,261 Views)
I solved my problem in the meantime. Thanks anyway
(3,239 Views)
