LabWindows/CVI
Calendar ActiveX Control
I'm using the Microsoft Calendar ActiveX Control to allow the user to select a date. I would like the value selected to update a control on another panel. I've created an ActiveX Controller for the control with the default prefix MSACAL. I'm then using the MSACAL_IcalendarGetValue to obtain the value selected by the user. This value is returned as a VARIANT. I follow this by using the function CA_VariantGetDate which saves the VARIANT value as a DATE value.
The difficulty I'm having is in the conversion of the value stored in my DATE variable back to a formatted date to be displayed at a later time.
Any input on this would be much appreciated.
James.
(4,456 Views)
I am not sure what exactly you are asking. Are you looking for a function to convert the DATE type back to VARIANT type, so that you can pass it back to the ActiveX Control?? If so, you can use CA_VariantSetDate function. I hope this helps.
Mika Fukuchi
(4,456 Views)
Mika,
What I am looking to do is to take the VARIANT returned from the Calendar ActiveX control and put it into a string control as a date formatted in dd/mm/yyyy format.
Thanks for your input
James
(4,456 Views)
From the Advanced >> Data Manipulation >> Variant palette, look at Variant to Data or Variant to Flattened String.
(4,456 Views)
Thanks for your help!
(4,456 Views)
Sorry: I got my forums confused. I gave a LabView answer to a CVI question. Oops.
(4,456 Views)
