LabWindows/CVI
Call External DLL on LabWindows
I have a LabWindows CVI 8.0.
I have a problem with any DLL with a USB Instrument.
From CD-ROM i get the library for interface my project with instrument (7 DLL files and one CHM Help file).
I haven't a LIB or Header Files.
Is possible with LabWindows call the DLL function ?
If is possible, can you write a example please?
Tommaso
(4,124 Views)
Ciao Tommaso,
 you can take a look at this document, that explains how to call DLLs in CVI without having the .LIB and the .H files:
How Can I Access DLL Functions in a LabWindows/CVI Program Without Including the Import Library in t...
If you have the .H file you can create the .LIB yourself in the way explained  in this other document:
Linking to Functions Defined in a DLL From LabWindows/CVI
 Hope this can help,
Ciao,
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(4,108 Views)
I have a problem.
I can't use a function if not declare a variable.
For example:
On DLL i have a class name -> TestOne
I haven't a Header file or Lib File, as I declare this class?
My problem is call this example: TestOne->DllFunction().
I verify with: GetProcAddress(hinstLib, "TestOne->DllFunction()");
But don't work fine.
Sorry for my english.
Thank you for your support
Tommaso
(4,077 Views)
I explane my problem with this project:
I have a example on Visual Studio C++, this is the code:
[On Header file]
IFiberChek2Ptr m_pFiberChek2;
[On code file]
m_pFiberChek2 = IFiberChek2Ptr( __uuidof(FiberChek2Window) );
[On TLH file]
struct __declspec(uuid("d381ffc3-b122-4a57-b4b0-549f6378ba9a"))
/* LIBID */ __FiberChek2Lib;
struct __declspec(uuid("b4947355-4670-4d03-af25-cbf22f86a6ef"))
/* dual interface */ IFiberChek2;
struct /* coclass */ FiberChek2Window;
// Smart pointer typedef declarations
_COM_SMARTPTR_TYPEDEF(IFiberChek2, __uuidof(IFiberChek2));
[I must call this function]
m_pFiberChek2->TestFiber();
Have you a advice for me?
Tommaso
(4,066 Views)
