LabWindows/CVI
Calling labwindows in labview
I need some real help.
Can someone give me a very simple example on  how to call a labwindows application in LABVIEW?
My labwindows application have to do some mesearments ....
I am using labwindows 8.5 and my Labview 10.
Thank you.
(3,753 Views)
Hi agyna,
I cannot give you a complete example, but you could find useful informations in this tutorial:
Tutorial: Calling a LabWindows/CVI DLL from a LabVIEW Application
(3,744 Views)
You might also want to look at putting your CVI code into a Function Panel. This has a number of advantages including the ability to document your code and CVI can automatically create the DLL project. Further more LV can then import the FP DLL via the "LabVIEW Instrument Driver Import Wizard (LabVIEW Interface Generator for LabWindows/CVI Instrument Drivers)", see http://lumen.ni.com/nicif/us/gb_infolvinstdriver/content.xhtml. This has the advantage that all the FP documentation is exposed in LV. Please note several odd quirks:
  1. Error cluster interface is not supported so you need to look at the wrapper VIs created
  2. This tool is not available for LV2010!
(3,734 Views)
thanks, I will try.
(3,718 Views)
