LabWindows/CVI
Can I add C++ classes to a CVI project?
I want to add a C++ library (Borland C++) to a CVI project. What is the best way to do it?
(2,981 Views)
CVI is a C compiler, not C++. You can't add C++ code into CVI. We are compatible with Borland C++ object code, but it has to be C code or the functions have to be extern "C" to be callable from CVI. You could build the code into a DLL in Borland and provide C-style functions to instantiate and access the class in the DLL.
Best Regards,
Chris Matthews
(2,981 Views)
