LabWindows/CVI
Can I change the size of point styles in a graph?
Hello!
In my application I plot points on a graph control. Furthermore I interpolate this points and draw a line between this points. All works fine but the size of the point style is too small. So if I plot the interpolated line (with PlotXY) the points (eg. point style is "bold X") can´t be seen very well. If I make a hardcopy of the graph the points can´t be seen anymore.
So can I increase the size of the point styles or is there an other possibility to mark the points?
Thanks!
Best Regards
Thomas
(2,858 Views)
You should be able to yes, although this is under the Strip Chart Traces it should also apply to graphs also...
Under:
Library,
User Interface,
Controls Graphs Strip Charts,
Graphs and Strip Charts,
Strip Chart Traces
Set Trace Attribute
Change [Trace Attribute] to [Point Style] and [Attribute Value] to one of the following:
Values:
VAL_EMPTY_SQUARE
VAL_SOLID_SQUARE
VAL_ASTERISK
VAL_DOTTED_EMPTY_SQUARE
VAL_DOTTED_SOLID_SQUARE
VAL_SOLID_DIAMOND
VAL_EMPTY_SQUARE_WITH_X
VAL_EMPTY_SQUARE_WITH_CROSS
VAL_BOLD_X
VAL_SMALL_SOLID_SQUARE
VAL_SIMPLE_DOT
VAL_EMPTY_CIRCLE
VAL_SOLID_CIRCLE
VAL_DOTTED_SOLID_CIRCLE
VAL_DOTTED_EMPTY_CIRCLE
VAL_BOLD_CROSS
VAL_CROSS
VAL_SMALL_CROSS
VAL_X
VAL_SMALL_X
VAL_DOTTED_SOLID_DIAMOND
VAL_EMPTY_DIAMOND
VAL_DOTTED_EMPTY_DIAMOND
VAL_SMALL_EMPTY_SQUARE
VAL_NO_POINT
(2,852 Views)
