LabWindows/CVI
Can I convert a LabVIEW Front Panel into a LabWindows / CVI User Interface File ?
I have a very elaborate Front Panel, developed in LabVIEW 8.6, which I'd like to import into my LabWindows/CVI 2013 development environment.
Is this possible?
If yes, please provide step-by-step guidance, if possible.
Thanks in advance!
(6,704 Views)
Hey Parrita,
I thinkt that it is not possible to convert a LabVIEW FrontPanel into a CVI FP.
I have never seen such a option and I think that noting like this exists.
If it is not possible to convert a VI into CVI code, it will be the same for the fronpanel.
Can I Convert LabVIEW VIs into LabWindows/CVI Software? - National Instruments
http://digital.ni.com/public.nsf/allkb/9018E4478599462A86256E8E0026F962
Regards
Stephan
(6,682 Views)
Hello Stephan,
thanks for your reply.
It is a pitty, since both products come from National Instruments and the buttons, controls, etc. all look so much alike.
If I could suggest an improvement to the LabVIEW and LabWindows/CVI IDE's, it would be that the FP and the UIR could be exchangable/portable among both IDE's.
Erick
(6,669 Views)
I've been a LabWindows user since version 1.0 and LabVIEW since 3.0 and I think I've converted 2 whole programs In that entire time so I think there isn't much call for such use but you can place such a request on the Idea Exchange.
(6,646 Views)
I already known that it's not possible to directly convert a LabVIEW VI into a LabWindows/CVI program.
But, could I do the opposite, I want to say, could I use code implementated in Labwindows like a vi to instert it in labview?
Thanks.
(3,981 Views)
Hello Cristina, you already opened a new discussion on this subject and is the correct way to do: please don't repeat your question over and over in multiple places.
(3,973 Views)
