LabWindows/CVI
Can I launch two tasks?
Halo! I need to sample data from two channels
of the same board. I'd like to use two
separate tasks, that should work on the same trigger.
Or there's a better way to do this?
(3,048 Views)
I don't think you will manage to acquire data from two channels with two different tasks: the second starting task will find the daq card busy and will get an error while configuring the application.
In your application you will need one acquisition task that takes care of both channels simultaneously, splits data and sends them to the appropriate managing task.
(3,048 Views)
