I need to use excel api's to build a 64-bit application which works for 64-bit o/s.
But, when i use these excel api's to build my 64-bit application from command line, i am getting linking errors whereas i am using the same libraries to build 32-bit application and this is being built.
So, here my doubt is that will the labwindows excel apis support for 64-bit o/s?
Please do help.
Thanks in advance.
Safer
