LabWindows/CVI
Can I manipulate the ODBC settings through SQL ?
What Im trying to do:
-Define a Database in ODBC through SQL.
-Delete a Database in ODBC through SQL.(Just the connection of course).
Is there an example somewhere ? link ?
Thanks a lot, David.
(2,997 Views)
No you can't because ODBC is not a functionnality of SQL. You can use the ODBC api to do what you want.
Another way is to connect to a database without DSN. You have to pass the parameter in the connection string.
(2,997 Views)
