LabWindows/CVI
Can I programmtically add a callback to a button
I would like to be able to conditionally add a different callback to the same button. Is this possible and what statement should I use?
Donna
(3,656 Views)
You can use the InstallCtrlCallback function.
Luis
(3,652 Views)
As Luis said, you can use the InstallCtrlCallback to install an existing function as a callback for the selected control. The function installed as a callback should have the same prototype as callbacks generated by CVI. It should also return 0 unless you want to swallow the event.
If panelHandle is the handle to a panel with the constant name PANEL which has a control with the constant name CONTROL, and you want the callback to be MyCallback and you don't want to pass any callback data,
installErr = InstallCtrlCallback (panelHandle, PANEL_CONTROL, MyCallback, 0);
int CVICALLBACK MyCallback (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
// your code goes here
break;
return 0;
(3,645 Views)
