LabWindows/CVI
Can I put a red outline around a control when values are not out of range?
I understand that when you set the ATTR_MIN_VALUE and the ATTR_MAX_VALUE for a control that a red outline will occur when the value is out of range. Is it possible to have the red outline occur around a control for a different reason? If so, how would I make this happen?
Donna
(3,489 Views)
It is not possible to obtain the red outline for other than the out-of-range condition.
In case you want to mimic this effect, you can put a color numeric below the control sizing it larger then the control itself; in the code you can assign to the color numeric the desired color for different conditions.
Roberto
(3,489 Views)
You can also mimic this behavior with a decoration control. Select Classic Style Controls >> Decoration >> Raised Frame.
You can toggle the red outline by setting ATTR_VISIBLE on the decoration control or you can toggle the color of the frame between red and transparent.
(3,489 Views)
Hi Donna.
Rather than creating an additional control on your panel, you could try this:
// Get the control's initial frame color
GetCtrlAttribute (panelHandle, myControlId, ATTR_FRAME_COLOR, &normalColor);
// Set the control's frame color based on whatever condition
SetCtrlAttribute (panelHandle, myControlId, ATTR_FRAME_COLOR, needRedOutline? VAL_RED: normalColor);
Colin.
(3,489 Views)
