LabWindows/CVI
Can I return ref cursor from plsql function in oracle using SQL Toolkit 2.1.0?
Is there a way to return a ref cursor from a stored function or procedure and iterate through it?  I have defined the simple package in Oracle below, and want to call the function or procedure and iterate through the rows returned.
I'm using LabWindows/CVI 8.5.0, with SQL Toolkit 2.1.0 on Windows XP, connecting to a 10.2.0.4.0 Oracle instance running on another server.
CREATE OR REPLACE PACKAGE emp_package IS  TYPE
type_ref_cursor IS REF CURSOR;
  FUNCTION get_emp_func RETURN type_ref_cursor;
  PROCEDURE get_emp_proc (empcursor OUT type_ref_cursor);
END;
CREATE OR REPLACE PACKAGE BODY emp_package IS
  IS
    tmp_cur type_ref_cursor;
  BEGIN
    OPEN tmp_cur FOR SELECT * FROM emp;
    RETURN tmp_cur;
END;
  IS
  BEGIN     OPEN
    empcursor := tmp_cur;
  END;
END;
(16,786 Views)
The LabWindows/CVI SQL Toolkit Help Lists SQL Statement Attributes that can be used. One that is mentioned is, ATTR_DB_STMT_CURSOR_TYPE which returns a cursor type. One cursor type that could be returned is DB_CURSOR_TYPE_DYNAMIC which will make additions, changes, and deletions by other users visible, and all types of movement through the recordset are allowed.
You can also use ATTR_DB_STMT_RECORDSET_OBJECT to obtain an ActiveX object handle of the recordset.
There is limited example code of doing this in LabWindows/CVI, but there are a few discussion forums that discuss this being done in LabVIEW. Please take a look at this forum as well as KnowledgeBase 4AJCSSLC: How Do I Set Input Parameters and Get Output Parameters from an SQL Stored P....
Adri Kruger
Adri Kruger
LabVIEW Product Marketing
(16,771 Views)
I've spent a few days testing different routes.  I finally figured out a way how to call the function and iterate through the returned cursor:
int test(const int hdbc)
 int resCode;
 int hstmt = 0;
 int i=0;
 char col1[101]="",col2[101]="";
 int stat1=0,stat2=0;
 // Set the command type attribute to store procedure.
 resCode = DBSetAttributeDefault (hdbc, ATTR_DB_COMMAND_TYPE,DB_COMMAND_STORED_PROC);
 // Prepare a statement that calls the stored procedure.
 hstmt = DBPrepareSQL (hdbc, "emp_package.get_emp_func");
 // Set command type attribute back to default.
 resCode = DBSetAttributeDefault (hdbc, ATTR_DB_COMMAND_TYPE,DB_COMMAND_UNKNOWN);
 // Bind columns
 resCode = DBBindColChar (hstmt, 1, 100, col1, &stat1, "");
 resCode = DBBindColChar (hstmt, 2, 100, col2, &stat2, "");
 // Execute the statement.
 resCode = DBExecutePreparedSQL (hstmt);
 // Loop thru columns in cursor
 while ((resCode = DBFetchNext (hstmt)) == DB_SUCCESS) {
  printf("col1=%s col2=%s",col1,col2);
 // Close the statement.
 resCode = DBClosePreparedSQL (hstmt);
 hstmt = DBDeactivateSQL (hstmt);
 return 0;
(16,742 Views)
